LatestVersion: 0.50a | Community: 0.70a
Discover Fake Files Using Webservices And Preview HelpNAV
Howto discover fake files
Webservices
After doing a search, you can check a file immediately by using webservices. Go to Options/General/Edit Web Services... and paste in the following lines:
ZITAT
Power-Portal,http://ed2kstats.power-portal.to/ed2k.php?hash=#hashid
Peerates,http://edk.peerates.net/check.php?hash=#hashid
Shortypower,http://ed2k.shortypower.dyndns.org/?hash=#hashid
edkfakes,http://www.edkfakes.info/action.php?link=#filesize:#hashid
DF Check,http://donkeyfakes.net/fakes.php?referer=emule&hash=#hashid&size=#filesize&name=#filename
DF Report,http://donkeyfakes.net/report.php?hash=#hashid&size=#filesize&name=#filename
Fake Check Bitzi,http://bitzi.com/lookup/ed2k:#hashid?ref=eMule
If your file isn't listed, you should check length/bitrate on plausibility and if provided different filenames for the file (only global search and kad)
Reading filenames and comments
After you connected to some/all sources for the download, you can check the different filenames or comments. Comments or 2 different filenames should concern you.
Empty files
A file downloading very fast with high compression (>100%) is often an indicator for a file filled with lots-of zeros. You should cancel these downloads immediately.
Preview
As soon as you downloaded the first 16 KBs, a preview can be successful. To enhance eMule's preview function, you should add the line
ZITAT
PreviewSmallBlocks=1
into the preferences.ini somewhere below "[eMule]" (emule may not be running when saving the preferences.ini!)
You can also create a file called "PreviewApps.dat" in the config dir, which could look like this:
ZITAT
VLC085=C:\Program Files\vlc\videolan\vlc.exe
MPlayer=C:\Program Files\MPlayerC\MPlayerC.exe
ACDSee=C:\Program Files\ACDSee\ACDSee32.exe
Videolan can be downloaded from here: http://videolan.org/vlc/download-windows.html and Media Player Classic here: http://sourceforge.net/project/showfiles.p...ackage_id=84358. Older and free versions of AcdSee (a fast and small image viewer) can be found here.
VLC plugin
The advantage of the plugin is, that VLC shows all downloaded data. It is recommended to use the according partfile plugin v0.1.4 for VLC 0.7.2 http://prdownloads.sf.net/emule/vlc-0.7.2_...v-0.1.4_bin.zip or v0.2.1 for VLC 0.8.4a http://www.geocities.com/sibermutant/023_binary.html
Determing real file extension
Sometimes a file has the wrong filename. A 100% working method to find out the real extension is to look into the file using a text/hex editor. Most of the time, the first 3 letters suffice for identification. Here is a short list.
ID3=.mp3
ÿû=.mp3
MZ=.exe (be careful with downloaded .exe files. You should always check them for viruses!)
PK=.zip
Rar=.rar
RIFF²ôáAVI=.avi
0&²=.wmv
???????**ACE**=.ace (?=wildcard)
Link sites
Of course, you don't need to do any of the above if you use a link site like i. e. http://contentdb.emule-project.net/
Translate this page Last Update: 27.05.2005 0:23
Internet Worm Protection
Firewalled On Kad No More!
How To Avoid Fake Files
Ipfilter.dat And Guarding.p2p
A4af - What Does It Mean?
I Need A New Server.met File!
How To Filter Ips With Emule
Problematic Software List
