Command Line Switches HelpNAV
Some of the basic functions in eMule may be controlled by command line switches. This allows execution in batch scripts or remote accessing eMule in a Telnet session.
Syntax:
emule.exe status
• status
Writes some information on current transfers to the file status.log
• connect
Connects to a server
• disconnect
Disconnects from a server
• limits=up,down
Sets the limits for up- and download speed. Same setting as in Preferences -> Connection -> Limits
• resume
Resumes any paused or stopped file in the downloads list
• restore
Restores a minimized eMule task
• ignoreinstances
Allows the execution of multiple eMule instances.
For two eMules running on the same machine they must be installed to different folders, must have different temp folders and also the ports used by each eMule have to be unique. It is not recommended to run two eMules concurrently apart from testing purposes.
• exit
Quits eMule
• assertfile
Debug option. Wrtites possible assert information to a file instead of breaking execution.
• reloadipf
Reloads the IP filter
Applies to version: .46a +
Last update on: 2005-06-05, Monk
Translate this page Last Update: 05.06.2005 20:28
  Protocol Obfuscation
Searching for Files
Credit System
Secure User Identification
Aggressive Client Ban
Source Exchange
Preview Multimedia Files
IRC Chat
Friends
IP Filters
Categories
eD2k Links
Source Management
Corruption Handling
