| ÀH¤U¦C²³æªº¨BÆJ¨Ó¬° eMule ³]©w±zªº Cisco 677 ©Î 678 ¸ô¥Ñ¾¹. ³o¬O°²©w¦b§A¥H PPPOE DSL ¨Ó³s½u¨Ã¥B¬O¤@Ó ÀRºA IP.
| ¦b±zªº¸ô¥Ñ¾¹ IP ¤¤¶}©l¤@Ó telnet °Ê§@. ¤èªk¦p¤U |
|   | a) ¨Ï¥Î Windows Hyper Terminal ¨Ã¥B¿é¤J¤@Ó ¦WºÙ  (¤£n¦³¬Û¦Pªº) ©ó³o¤@¦¸°Ê§@, ¿ï¾Ü  TCP/IP (Winsock) ¬°³s½uÃþ«¬µM«á¿é¤J ±zªº¸ô¥Ñ¾¹ LAN IP (¤@¯ë¬° 10.0.0.1 ©Î 192.168.0.1, ¦ý¥i¯à¤£¤@¼Ë) ¬°¥D¾÷¦ì§} |
|   | ©Î |
|   | b) ¥h¨ì[¶}©l]¥\¯àªí -> °õ¦æ -> telnet ¸ô¥Ñ¾¹ªº LAN IP (¤@¯ë¬° 10.0.0.1 ©Î 192.168.0.1, ¦ý¥i¯à¤£¤@¼Ë) |
| ¦b telent ³s½uª¬ºA¤U¤@¦¸¤@¦C¿é¤J³o¨Çªº«ü¥O: |
|   | ±zªº±K½X(¥Ñ±zªº ISP ´£¨Ñ, °²¦p¨S§ïÅܬO cisco )enable
 ±zªº±K½X (¥Ñ±zªº ISP ´£¨Ñ, °²¦p¨S§ïÅܬO cisco )
 set nat entry add LAN IP  4662 WAN IP 4662 tcp
 set nat entry add LAN IP  4672 WAN IP 4672 udp
 write
 reboot
| WAN IP ¬O±z¦bºô¸ô¤W¦³ªº IP (¸ô¥Ñ¾¹ªº¥~³¡ IP) ¤Î LAN IP ¬O°õ¦æ eMule ¹q¸£ªº IP. |
| ª`·N:°²¦p¥ô¦ó¤Hª¾¹D¦p¦ó³]©w³oÓ¸ô¥Ñ¾¹¦b°ÊºA¤À°t IP, ½Ð±H«Hµ¹ Monk
